error using database toolkit
I'm using a DB Tools open Conection.......to get data from a SQL database....when I run the VI's it appears the following error:
Error -2147467259 occurred at DB Tools Open Connec (String).vi->connect_sql(1).vi
Possible reason(s):
Exception occured in Microsoft OLE DB Provider for ODBC Drivers, [MySQL][ODBC 3.51 Driver]Too many connections.  in DB Tools Open Connec (String).vi->connect_sql(1).vi
I don't know why it happens.....i've attached the sub vi's. It can be the drivers I'm using for this database?
(3,685 Views)
The error is described as too many connections, so this probably happens because you open a connection and then try to open another without closing the first (or whatever number of connections you can have open simultaneously). Move the open connection out of the loop, place a close connection after the loop and make sure you have a proper way to stop the loop. If you only want to run this once, you don't need the loop. This is also true if you want to run it as a subVI.
These things apply to any reference based action in LV (TCP, File I/O, queues and so on) - You need to open a resource once, use the reference you get in all the functions you need and then close the resource.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here and here are a couple you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
___________________
Try to take over the world!
(3,680 Views)
am using database toolkit and i have this error code appearing  -2147217900 when i try to use update data.vi .
(3,082 Views)
