error "Wire: is a member of a cycle
I am doing decoupling control of MIMO system in LabVIEW Control Design and Simulation module. Simulating the controller and the plant transfer functions, gives the error "Wire: is a member of a cycle".I understand this is coz of the Three transfer functions in the trnsfer matrix having equal number of poles & zeroes showing Direct feed through behavior. As I can make no changes in the plant or controller models, can anyone suggest a possible solution for this?plzz
Message 1 of 16
(7,688 Views)
Can you post a screen shot of your vi?
Message 2 of 16
(7,653 Views)
Sir,
I have attached the screen shot of block diagram of the vi. The transfer function blocks of the plant which are circled in red are showing direct feed through behavior (equal number of poles and zeroes) and they contribute to the error in the vi. Is there any configuration settings change that can be made for resolving this? Can you help me with this?
Message 3 of 16
(7,620 Views)
That error means you connected the output of something to its input.  FYI - In case you didn't know it, you could look this up in the LabVIEW help.
Bill
CLD
(Mid-Level minion.)
Message 4 of 16
(7,611 Views)
you have connected output of "levelsp" to "7"
Message 5 of 16
(7,602 Views)
Sir , the output from 7 is given to the negative node of the summer near level SP(to 10) . In the bd, it looks like both are given to the same node is just a mistake happened while cleaning the wires in the diagram . However the connections were correct. I have attached the screen shot again.
Message 6 of 16
(7,589 Views)
It would be more convenient to have a code.
CLAD
Passionate for LabVIEW
Message 7 of 16
(7,579 Views)
oops never mind too early in the morning
Bill
CLD
(Mid-Level minion.)
Message 8 of 16
(7,560 Views)
I would suggest ctrl+B to delete all the broken wires then rewire what disappeared.
Bill
CLD
(Mid-Level minion.)
Message 9 of 16
(7,545 Views)
Accepted by topic author krishnapriyapg
Well, that is your cycle: "the output from 7 is given to the negative node of the summer near level SP(to 10)". You should insert a feedback node there and initialize it to 0.
Ben64
Message 10 of 16
(7,528 Views)
