error out problems with measuring frequency VI
I am having some error out problems with measure frequency VI. The instructions is change error out from indicator to control but does not work. Anyone can help? The VI is attached
(2,533 Views)
This VI does not have an error out. Obviously, you replaced a subVI that did have an error out with this one, otherwise you would not have been able to create this wire.
Simply remove the wire or save the subVI with another name then modify it to have the error out that you are looking for.
Hope that this helps,
Bob
(2,528 Views)
