09-22-2006 04:49 AM
09-22-2006 03:44 PM
You should try to run one of the example VI like:
Cont Acq&Graph Multiple Voltages-Int Clk.vi
Don't forget to configure your AI Channels with the task configuration utility before you build your PDA App.
One other comment your New File VI should not be in your READ LOOP.
I've used the same IPAQ and DAQ card. If I can help more let me know.
Eric
09-23-2006 11:56 AM
09-25-2006 12:17 PM
09-25-2006 06:58 PM
09-26-2006 11:13 AM
09-26-2006 11:22 PM
09-27-2006 10:35 AM
09-28-2006 04:20 PM - edited 09-28-2006 04:20 PM
Message Edité par edta le 09-28-2006 04:21 PM
09-28-2006 04:40 PM
As you can see I ran into the same problem your having.
http://forums.ni.com/ni/board/message?board.id=170&message.id=89556&requireLogin=False
What do you have set for your scan rate and number of samples to read?
I'm going to see if I can find another reference to that error code.
Good Luck
Eric
