error occurred during controlling PLC using Modbus
Hi
I'd like to control a motor via PLC using Labview modbus, i can control the motor to rotate while given a certain parameters (angle), but when i want to read the angle of motor during the motor rotation, there will be an error. i also tried reading the angle motor separately, and it works.  could any guys help me?
thanks.
(2,944 Views)
(2,904 Views)
Thanks for your reply.
i think the problem you mentioned in the post is he has two slaves, but i only have one. i try to clean the specific error which i get during test, up to now, it works, but i am not sure it's the right way to solve the problem.
thanks again.
(2,890 Views)
