error occurred at Load Velocity in RPM.flx
I had a runtime error as following while reversing my motor.
Error -70154 occurred at Load Velocity in RPM.flx
Possible reasons:
Motion: The input or return vector being used is invalid
(2,807 Views)
I'm assuming you already validated all your inputs and the return vector address.
- Are you writing the velocity value to the onboard memory?
- What are the parameters that you're passing to the function?
Yusuf C.
Applications Engineering
(2,807 Views)
