error message
Dear forum members i attached file where shown Labview error message.
What i should do to solve this problem? What means this problem? Are the problem come from  Labview or from Device?
Thanks in advance
Warm regards
Harut!
(3,682 Views)
Hi Harut,
can you give us more informations about what you do? Smiley Happy
Mike
(3,681 Views)
I am programming Network analyzer serial type. if 126data point (Trace point) about 1300bytes read, when 251data points 3800bytes read, but if 501data points, read only 4096bytes and show this error message. I increase timeout and Delay time before read, but same error. More than 4096bytes cannot read..
Why? Could you give me any explanation? What i did wrong?
(3,676 Views)
Hi Melikyan,
it sounds like your i/o buffer has only a size of 4096. This is the default value in the "Advanced Serial Read and Write" example. If you change this value, it should be possible to read more bytes. Smiley Happy
Hope it helps.
Mike
(3,671 Views)
How to change? Could you attach one simple example?
Thanks in advance...
Harut!
(3,667 Views)
Hi Harut,
you can see it in the "Advanced Serial Read and Write" example.
Mike
Message Edited by MikeS81 on 05-21-2008 10:41 AM
(3,665 Views)
Thank you so much. i never thinked that 4096bytes default and have limitation.
(3,638 Views)
