error loading C:\Program Files\....\resource\ivanlys.dll "a dynamic link library initialization routine failed"
Hi all,
After installing my labview, I tried to use the tutorial:when I launch (double click on the create new menu) the "Generate and Display VI" I get the error message:
This is the same if I try to launch other VI.
What can I do?
(3,343 Views)
could you be more precise in describing what you did to obtain that kind of error you had? Which LabVIEW version do you have?
I suspect that there was something wrong with your LabVIEW installation process. I suggest you to uninstall and install again LabVIEW on your computer.
I await for your news!
Ale
(3,309 Views)
