error line 367
Hi all :
what the meaning of this error ,, its make me crazy .. when i run labview suddenly in appears .. i dont know from where its comes
I am using subvi , dll ,,i check all the dll its work perfect and check the subvi separately and also its work
what i am donig wrong ????
thanks
(3,196 Views)
That's most likely from LabVIEW doing a sanity check on your front panel control. Usually this is caused by something becoming corrupt on the front panel. Your best bet is to delete front panel controls and/or indicators and then replace them with new ones. Do this one at a time until you find the culprit. Don't just right-click on the control/indicator and select "Replace". You have to actually delete it and place a new one on the front panel.
Message Edited by smercurio_fc on 03-27-2008 12:41 PM
(3,183 Views)
Hi Elyan,
Smercurio_fc is right,
but if replacing the front panel objects don't work
Please try the following knowledgebase Editing LabVIEW Property Nodes Can Cause Insanities or Crashing
Hope that helps
Sorry for the inconvenice
Van L
NI Applications Engineer
(3,166 Views)
