error is generated when a vi is called dynamically in exe
i havew the following attached vi's
I call the untitled1.vi dynamically from the untitled2.vi. using the load vi dynamically.vi. i dont get any error meassage when i run in the scource code. But when i build the code, i get the error in opening the untitled2.vi.
Can u exp-lain me why is this and how to over come this. I found that when i open the front panel of the dynamically loaded vi i can over come this problem. Is there any other way to do this.
(3,483 Views)
In Application Builder on Tab "VI SEttings" find your vi and set option "Remove panel = no".
I think this is your problem.
(3,483 Views)
It looks like you are trying to do something that is not available in the runtime engine. The error 1043 is referring to arg1 at a property node in the Load VI Dynamically.vi but you have this locked with a password.
Regards
Ray Farmer
Regards
Ray Farmer
(3,483 Views)
Thanks for ur answer,
I have attached the same files with removing the password. Please guide through this.
(3,483 Views)
The Execution:Show Front Panel On Load Property is read only with the Runtime Engine.
Remove this property and your exe will work fine.
Regards
Ray Farmer
Regards
Ray Farmer
(3,483 Views)
Dear MR Ray Farmer
I removed The Execution:Show Front Panel On Load Property. I am getting the error 15. Can u guide me through this. I am attaching the changed vi's
(3,483 Views)
The Untitled1.vi needed the Remove Panel to be set to 'NO' in the app builder VI Settings Tab.
I've attached modified files and exe. (I have put the open front panel property node back in so that I can see it launched back it works fine if you dont want to see the panel so you can set the boolean false or remove the Node.)
Regards
Ray Farmer
Regards
Ray Farmer
(3,483 Views)
