error in
If I've developed a VI using a certain DAQ Device, assuming that I assure that every following application will be using the same DAQ device and sensor configuration, will my future users need MAX or anything special to run the application?
(2,651 Views)
Depends on what you want to give the user,
If you give only the application VI, its obvious that the user needs LabVIEW and MAX on his system to run your application vi
You can also give a stand alone application (executable) of your VI
see here and here
This Link explains how to include hardware configuration from MAX and relevant DAQmx device driver for your hardware
Message Edited by devchander on 04-10-2007 01:52 AM
Message Edited by devchander on 04-10-2007 01:55 AM
(2,649 Views)
