Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
12-01-2008 12:20 AM
I am writing to an xml file and in a parralel loop i have to read from the same xml.
this is throwing an error in unflatten from xml saying the xml tags are invalid.
Is the simultaneous access not handled by Labview(8.6) for xml files?
I tried to search the forum but could not find a thread on the same.
Kindly let me know if this has been discussed earlier.
Regards
12-01-2008 06:47 AM
Hi Gsingh,
I am not sure if you can/or can't. But why would you want to introduce this race condition? Surely, you would be better of writing to xlm and then sending a notifier to the second loop to signal that the file is now ready to be read.
If your not familiar with Notifiers (or other types) of syncrhonization within loops, please take a look at these KnowledgeBase articles and links:
What Is a Notifier?
http://digital.ni.com/public.nsf/allkb/B9398355D9550EAF862566F20009DE19?OpenDocument
Please let me know if this helps,
Kind Regards,
James.
12-01-2008 11:05 PM
Hi James,
Thanks a lot for the info...
In my application i write configuration settings in an xml in a VI and a seperate parallel VI has to read this configuration for its every operation.
also as soon as the configuration is updated the parallel vi should take up the new configuration.
I'll try implementing the same with notifiers and check out if it works..
Thanks again..
Regards
Gagan
12-02-2008 05:38 AM
Hi Gagan,
Thanks for the update and I hope your well today.
I would consider the notify approach just to avoid reading the same line twice or missing a line in your configuration file.
Please let me know how you get on and if you have any problems.
Kind Regards,
James.
