error in making an .exe file
hello..
   i just make a labview file  and tried to make an .exe file..
i show error..   missing of  file path of an  Icon.. it is in NI Library file..
Why it is not taking the path from thr..
 it also showing error that.it may be due to the moving or deleting the File..
Please suggest a Solution to debugg this problem soon..
TIJU
Regards
Tiju Thomas
Message 1 of 8
(3,895 Views)
OK, since you say that the problem it's on the icon path, have you tried to add another icon to the project and build with it? It appears to be a small detail. The best thing it's to do again in order to clean the error.
if you want you can send me your project and I can try it here
Software developer
www.mcm-electronics.com
PORTUGAL
Message 2 of 8
(3,866 Views)
Hi TIJU,
Can you provide more details? Good information could be the specific error code, screenshot of the error, which icon it is missing, or your version of LabVIEW. With more information we should be able to help you out.
Hillary E
Message 3 of 8
(3,853 Views)
TIJU wrote:
hello..
Hai,
Try to collect all the files in a single folder and try to build exe again.
Hope this helps!
Mathan
Don't forget to rate a good answer.Smiley Happy
Message 4 of 8
(3,837 Views)
Hai,  Mr Mathan,
 U r right.it was because of the missing of filees from a particular ni library file.
i made it in a folder and so i can build the exe file..
tHANx
TIJU
Regards
Tiju Thomas
Message 5 of 8
(3,822 Views)
Hai Hillary..
  i use Labview 8.0..it is showing the Excel_Quit.vi  couldn't have path..as error..after running the build.
that particular Vi's was not shown in the Dependencies Of the  Main VI..
well it is in the NI library folder.. the folder name is _excelsub.llb..
Is it because of theat UNDER-SCORE symbol in that library..
TIJU
Regards
Tiju Thomas
Message 6 of 8
(3,821 Views)
Hi TIJU,
So did you get your executable built and running properly or are you still encountering an error?
Hillary E
Message 7 of 8
(3,801 Views)
Hii  Hillary..
     Yeah i get the executable build atlast..well thanx alot for ur support..
Regards
TIJU
Regards
Tiju Thomas
Message 8 of 8
(3,788 Views)
