error in delete SubVI
in the attachment there is a vi called "ShowMessage". this vi creates a copy of the message.vi.
the created message vi should be deleted after closing.the problem is to delete this vi.
if the DeleteTempVi.vi is called the path of the vi to delete is sometime wrong.
where should be the problem?
markus
(2,963 Views)
It's not at all clear what it is that you're trying to accomplish. I can see what it's doing, but not what it's trying to accomplish. Why do you need to copy a VI just to display a message?
(2,943 Views)
hello,
in my application there are many error- messages. if an error occurs a message will be shown, and the programm continous.
when i use the normal message vi the programm stopps until the user accept the message on the screen.
so my idea was to create a vi which will be copied, shown and deleted when the used pushed the button.
unfortunately, i think,  the delete.vi sometimes doesn't works right.
markus
(2,932 Views)
Hi Markus
That's no problem - you just have to show the message in a separate loop, so the rest of the application can execute without any problem. That's one of the biggest advantages of LV - make loops run in parallel very easily.
I attached a very simple vi, that shows what I mean.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,928 Views)
hello,
thanks for your answer.
i've found the problem in my vi's but can't solve it.
i found out that the delete.vi doesn't delete the actual vi. it deletes the vi created before.
the curious thing is that the debugger shows the right path in the deletepath- object (deletetempvi.vi) but wants to delete the vi before.
i hope someone can help me.
markus
(2,909 Views)
I'm sorry, but I don't mean to be blunt, but the right way to fix your problem is to not do it the way you're trying to do it - it simply doesn't make sense. Take a look at becktho's example.
(2,900 Views)
