error in Pi value
Discovered a bug in the labVIEW constant for Pi.
Actual value 3.14159265358979323846 according to a number of sites (http://www.geom.uiuc.edu/~huberty/math5337/groupe/digits.html),
LabVIEW value for Pi when indicator is set to 25  digits of precision ((only shows up to 16 decimal points which is probably the limit) : 3.1415926535897931
The last digit should stay rounded at 2, and if the precision went one more, then we would see the 3 round up to 4 because of the 8.
This causes issues believe it or not when solving some equations, it took us awhile to find it.
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
Message 1 of 22
(6,385 Views)
Hi eximo,
is this issue maybe related to the limited accuracy of floating point numbers?
Which numeric representation do you use?
Message 2 of 22
(6,381 Views)
That's a limitation of double precision numbers. There is no way to represent 3.1415926535897932 as a double precision number.
You can try using extended precision numbers.
Message 3 of 22
(6,380 Views)
LabVIEW help for pi constant says 3.1415926535897932.  If it can't be represented properly at double precision, NI shouldn't be storing it as such.  I'd call that a bug.
Message 4 of 22
(6,359 Views)
Hi mancho,
why should it be called a bug when you get the best DBL you can get for pi? You can switch the pi constant to SGL or EXT...
Message 5 of 22
(6,352 Views)
*Sigh* Pi to two decimal places is good enough to insert a probe into orbit around Jupiter.
Bill
CLD
(Mid-Level minion.)
Message 6 of 22
(6,348 Views)
@GerdW wrote:
Hi mancho,
.... You can switch the pi constant to SGL or EXT...
I didn't even know you could change representation of constants.  That's interesting.  Thanks.
Message 7 of 22
(6,341 Views)
To answer GerdW , I'm using extended precision.  For my system, it allows for ~17 digits of precision.
-Regards
eximo
Neuronetrix
Message 8 of 22
(6,340 Views)
Yes, but you may prefer more precision if they put a probe in Uranus.Smiley Wink
Message 9 of 22
(6,324 Views)
This is strange!  If you change the Pi constant to extended precision and wire it to an Extended indicator, you get the correct "2" digit at position 16 (but can't display additional numbers).  It does look like going to Extended (at least for Pi) can get you another decimal digit ...  Weird.  I'm not sure whether to call this a Bug or a Feature.
Message 10 of 22
(6,320 Views)
