error code problem and sub vi help.
 i am getting an error at the automation open with an error saying it is not wired to correct input numberi.It did not happen before i had a manual input these values from the user. now i m using the output values from the result. I need to write the value in the vref register with the vref register value.. also i need to know how can i create the subvi for the write and read functions i have in my current vi. and to use it multiple times in another vi. i have been following the tutorial and LV help but havent actually got the thing work my desired way..any help will be grateful.
Thanks..
(2,606 Views)
hi. i figured out the probs...
thanks
(2,591 Views)
