error code-33587
I have a troble while i am traying to read the values from the FP-1000.
I have configurate it and I can read the values from the FieldPoint explorer, but when I am traying to read the values from my application, the FP Read return a error code 33587.
the FP Open, and FP Custom Created Tag, work "OK", but i guess the problem is on FP Read wich returns error codes 33587.
How can I solve it ?
(3,155 Views)
Omar,
The 33587 code tells me that you are using a multi-channel item (e.g. the "All" tag) and that one or more channels are reporting an "Out of Range Error".
Look at the online help under the FieldPoint Specific Codes section: "If the FieldPoint server error code is greater than 33586, the return code indicates that some of, but not all, the channels associated with your FieldPoint item have a Module Error code:
Module Error Code = FieldPoint Error Code � 33586". Thus one or more channels is reporting error code 1, "Out of Range". My guess is that you do not have signals hooked up to all of the channels, or that a signal is too large. Double checking your wiring and configuration of the module will allow you to solve the problem.
Aaron
LabVIEW Champion, CLA, CPI
(3,154 Views)
Hello Omar:
I am having the same problem.
I have cheked all my wiring, voltages, currents. I have checked my software modules. I just can not find a reason for this error.
Have you been able to solve it.
(3,069 Views)
