error LAN connection but Remote Desktop works
Hi ,
I have a Signal Generator connected via crossed cable in LAN. The "Remote Desktop" works perfectly fine, but the MAX doesn't see the device although I put the same address in. To mention that I don't use Remote Desktop and MAX at the same time.
Attached Error code.
Regards
Y3G
(2,964 Views)
Maybe it's the VISA string you are using. The R&S SMA100 Release notes show almost exactly the same string:
TCPIP::192.168.1.33::INSTR
If you have more than one Ethernet card, you may need to use a one instead of a 0 for the instance
TCPIP1::192.168.1.33::INSTR
You could also let MAX try and autodetect your instrument...
(2,955 Views)
The Error was initiated by MAX (see in the background) while trying to Autodetect.
An additional Info is that I am using 2 IP connections (USB2Ethernet and the normal 10Base connection)
While trying to ping from the DUT to the PC it worked but trying to ping from PC to DUT the ping "timed out" (=100% loss)
Doing IPCONFIG I can verify 2 Ethernet addresses.
Thanks for any hint.
Y3G
(2,943 Views)
Hi Y3G,
Would it be possible for you to unplug one of the ethernet devices from your computer temporarily and see if you could connect to it in MAX then? I'm a little concerned about IP address confusion/conflicts.
-Sam F, DAQ Marketing Manager
(2,923 Views)
