error 85
labview 2018
we are  trying to do 6220 & 2182a delta mode and already download the dirver.
we got driver of delta mode and when we run it, there comes out error code 85.
the error content is "false to scan. input string doesnt have data that is not expected format "
(we are not english user, so we translated it into english.)
So we checked subVI, and recognized there is a blank at 2182a response string, and i think that is the cause of the error, but i have no idea of solving it.
anybody know about this problem to solve it?
i attach three vi capture file.
(2,824 Views)
Hi sin,
you already got an error at start of the VI so which answer do you expect?
Where do you initialise the VISA reference?
Btw. please don't use non-ASCII chars in filenames (like your Korean characters). Use only plain simple English names to help others being able to open/display those files…
(2,796 Views)
As GerdWthere are problems on the inputs because the error occurs at the first vi
You should look into 6220 input string from its datasheet or manual.
The input string should be in English.
(2,770 Views)
