error 8 File permission error while building executable for a RT
I got error 8 File permission error while building executable for a RT. It happened always after build, I mean new startup.rtexe and startup.alias files have been created. At the build properties, it was set use default .alias file.
I had the executable built successfully at one time.
The detail message is:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 8 occurred at Open/Create/Replace File in RTBEP_Generate_Deploy_Instructions.vi->RTBEP_Invoke_Build_Engine.vi->RTBUIP_Build_Invoke.vi->RTBUIP_Build_Rule_Editor.vi->RTBUIP_Open_Properties.vi->RTBUIP_Item_OnDoProperties.vi->RTBUIP_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File permission error. You do not have the correct permissions for the file.
NI-488:  DMA hardware error detected.
I checked relevant posts, couldn't find any clue.
Please give me some ideas.
Thanks.
(3,287 Views)
Hi Ya-hoo,
Error building application in LabView 8.0 seems to describe a similar situation. The .alias file is important, as described in that discussion forum.
Cheers.
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(3,269 Views)
