error 62
I am communicating between two computers running two applications using TCP/IP connection. someitmes I am getting error 62, can some one explain me what this error means and how can I fix the issue. I appreciate your help.
here some great links: livesexcams.name , nudecams.name , livecamgirls.name
(2,234 Views)
Hi womucesi,
right-click the error cluster indicator and select "Explain error"…
(2,214 Views)
Help->Explain Error...type 62 into the code..."The system caused the network connection to be aborted."
One possibility that comes to mind is if you do not have any traffic for some time, Windows will close the connection for you.  The solution is to send a watchdog command back and forth every minute or so to keep the connection active.
(2,200 Views)
