error 42 create folder
Hi everybody,
Test System is WinXP with LV8.2.
In the course of the vi I dynamically load VIs, create folders etc without a hitch. However after compiling to an executable,  I get error 42 when creating a folder or an error 8 when trying to open a vi reference.
Help would be much appreciated
Schorsch
(3,984 Views)
Hi Schorsch,
are you sure that your paths are correct? If you build an executable, then the function "getcurrentvi´spath" gives following back. C:\your.exe\your.vi.
Hope it helps.
Mike
(3,983 Views)
This, this and this may help.
(3,979 Views)
I have a little sub VI I always use when opening/creating files/folders. Gives a relative path to the file. (It's in 8.5 can save for something else if you need.)
(3,978 Views)
Thanks for vi,
gave me an idea and solved the problem! Smiley Very Happy
(3,975 Views)
