error 301994 using 5641R
I am using a RT system implemented on a PXI-8108 controller mounted inside a 1062 chassis.
The system also includes two PXIe-5641R fgpas boards, mounted inside the same chassis.
I am trying to configure the IO ports of the FPGAs from the RT controller by using the library made by NI to program the 5641R boards.
I am getting the following error:
Error -301994 occurred at ni5640R Template.lvlib:ni5640R DAC Get Calibrated Correction Factor.vi
I have tracked the error and it seems to come from the following subVI (provided by NI): Reed Cal Date (EEPROM).vi
Now, what is puzzling me most is that the whole system used to work fine. I haven't turn it on for a while (6 months) and now I have got this error message.
I couldn't find any documentation about this error message.
Does anybody has any clue about the meaning of the error?
Message 1 of 1
(2,490 Views)
