error -222
So I am running a program and the error message -222 appears every so often causing an anomaly in my data. I am not sure why, I have attached the sub Vi I am using causing this error, which only measures a marker height on a spectrum analyser (using Tek signalVu-PC).
When the error message does appear I can just continue and it will keep going with the measurements but leave a 0 in the array the data is being uploaded to.
  • on the error message the “why no found?” is no help
  • I don’t think the data is out of range because I am monitoring the analyser and the marker is clearly on the peak within the reference level (dBm)
If you have any suggestions please let me know,
Thanks for any assistance
Z
(5,234 Views)
Accepted by topic author zandrous
Update,
I have solved the problem.
I have fixed the error so that the sub vi just re runs until the error is no more.
(5,153 Views)
