error -2146960888 when opening excel from labview using active x
attempting to open an instance of excel from labview using active x, I even tried using the "open excel and make visible.vi" found on this site. I get errors every time, Inserting a break right after the property node, I found that it does open excel with no active workbook. once the program runs to ompletion excel terminates. The error is on the line right after the property node executes.
(2,605 Views)
I am a little confused. Does the VI work and just generates an error, or does it not even work?
I searched NI's site, Microsoft's site, and google and that error does not show up, so I am at a loss as to why Excel is returning the error.
Can you attach a link or the VI itself so we can look at it.
(2,605 Views)
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3F15456A4E034080020E74861&p_node=DZ53003&p_submitted=N&p_rank=&p_answer=&p_source=External
(2,605 Views)
