02-21-2007 09:45 AM
02-22-2007 07:11 PM
02-23-2007 10:28 AM
02-26-2007 07:45 PM
02-27-2007 11:12 AM
02-28-2007 11:33 PM
03-01-2007 10:42 AM
03-02-2007 12:08 PM
03-05-2007 11:10 AM
As I said before I was not able to reproduce this error through simulation, but only using the DAQ card to try to read values. I have included a screenshot of a smal program I used to reproduce the error. The sequence does not need to be in this code actually, but if I put a delay int he first frame it remedies the error. ALso, when using the task done vi, the output of the vi is not connected to anything. The start vi simply passes the task name and error line to it, and it passes these on to the read vi. I'm not sure if this should even do anthing, but it also remedies the error.
Steve
03-06-2007 01:04 PM
