error-201003
Greetings.  I am getting error-201003 each time I run my code.  I have copied the DAQ assitant sub-vi from another vi where it is working perfectly.  I feel that this should rule out ni-daqmx settings as my problem.  Has anyone had a problem like this before?
(3,806 Views)
Hi Pushrod,
What hardware are you using?  Can you attempt to recreate the DAQ Assistant from scratch in the VI you are wanting to run?  Check to make sure you are still referencing your DAQ device in the right Dev identifier.
Kyle A.
Chief Applications Engineer
(3,789 Views)
