02-16-2007 05:51 PM
02-19-2007 05:18 PM
Hello Steve,
You probably have a shared variable in this library that has the "Bind to Source" option checked in its properties but the path for that binding is either incorrect or empty. Make sure all the variables in this library have valid bindings. Also try deploying a new library to new variables make sure that there is nothing else wrong.
Chetan K
Application Engineering
