07-28-2006 01:57 AM
hello matt,
yes i have removed the old library ... infact deleted from the system itself.
Ramji
07-28-2006 03:57 AM
LabView 8 doesn't find the shared variables by name. This can cause the error code 1950679035, when you have several shared variable libraries with the same name , in different file folders.
If you click a sv with richt mous click and select visible items -> label , then only a project explorer like path is shown, instead of an absolute path. Thats why references of sv may be errouneous.
The solution is to write the absolute path to the sv programmatically or by any ini file. As far as I know this is not yet possible in LV8.
DG3005
01-24-2007 07:14 AM
01-25-2007 10:09 AM
