error 1430
I was trying to code a vi that is capable of writing a text log file whose name includes the date and time, but it does not create text file and create error 1430. When I deleted format date/time string function and wired the name of the file directly to the open file function, it worked without errors. What is wronh here?
Egemen
(11,544 Views)
Its because you have "/" in your date (for example 27/02/2013). Windows wont allow that. Replace that with some other allowed character and you will be fine.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(11,542 Views)
I checked its result and it does not write "/", it uses dot in indicator (27.02.2013) in date. Oh ok, I recognize that it uses semicolon while writing time. How could I change it?
Egemen
(11,534 Views)
Then it will be the ":" in the time stamp. It is not a good idea to do this without using proper formats, as %c  displays local-specific time stamp. So if it is used elsewhere or if someone changes the system settings, your code will error. So you may want to specify a proper format which will remain constant instead of %c
Also use close file http://zone.ni.com/reference/en-XX/help/371361J-01/glang/close_file/ after you have written to it to close the reference you opened. This is good practice.
(11,522 Views)
Accepted by topic author newbieeng
I tend to format my data/times for a file something like this:
(11,513 Views)
Thank you Crossrulz. I got it.
Egemen
(11,503 Views)
