error 1406 during application installations
When installing more than 1 Labview applications on my computer that were created using version 6.1 I get the following error messages:
ERROR 1406. Could not write value version major to key UNKNOWN\Products\37212F9246F95954C8E26D4561F02FFB\InstallProperties. Verift that you have sufficient access to that key.
If I select ignore another error 1406 message apears.
This only happens after one labview in installed error free and installation of another is attempeted.
Any Ideas?
(3,403 Views)
There are several NI KnowledgeBase articles that potentially provide answers to the installation problems you are seeing.
The first (2CRF5B1R) relates to the Windows Registry being at its maximum size and therefore not being able to write the additional keys as required by the installer. From experience this is rare, but the article is worth reading and considering.
The second (2OK8222G) states that this error may occur if you use a non-numeric character in the product version entry in the Application Builder dialog. The article provides more of an explanation - so its not worth repeating here.
Jump to the KnowledgeBase at the following link:
http://digital.ni.com/public.nsf/MainPage?OpenForm&node=133020_US
Hope this information resolves you
r problems.
Jeremy
(3,403 Views)
