error 1124: executable and dynamic sub VI's
I have a labview file that dynamically calls a subVI. It works well in the VI, but when I go to create the executable I get errors. I put the subVI into the always included source files in the builder and moved the subVI into the folder with the newly built executable. I then get an error 1124, or if i move the subVI to another location I get error 1125.... I have been stuck on this for a while and cant seem to get anywhere with the current postings for error 1124.
khoward.vi
-Stand back! I am going to use science!
(3,628 Views)
Do you use a relative path for the the VI you dynamically call?
(3,621 Views)
(3,609 Views)
I use a ge vi path.vi that reads to an open vi reference.vi. I just need to specify the string of the vi i want to launch
khoward.vi
(3,592 Views)
And the path is correct ?
Try to make a indicator on the path to see what the path is when you are runing the exe file.
(3,590 Views)
The path appears to be correct. The error says that a possible source is that the VI being called is a polymorphic VI...
khoward.vi
(3,587 Views)
khoward.vi
(3,586 Views)
