error 1074135039
Hi everybody, I have installed a PCI-6034E card in my computer and I would like to visualize a signal on the attached vi. A dialog box gives me the following text:
"Error-1074135039 occured at niFgen Initialize.vi ...
This is not a supported device."
Although I have entered the device name and number "Dev2", which MAX has given me. Best, Ninskaya
(3,564 Views)
You get the error because the card is not one of NI's function generators and NI-FGEN is only for them. NI function generators include the 5411 and 5421. You can only use DAQmx  functions with your card.
(3,554 Views)
Hi Dennis, thanks a lot for your answer. Do you know where I could find vi examples to visualize signals from the PCI-6034E card. I am using LabVIEW 7.1 and have downloaded DAQmx 7.1 but can not find any examples there? Best, Ninskaya
(3,548 Views)
Help>Find Examples.Smiley Wink
There's a whole big section for DAQmx under the Hardware Input and Output section.
(3,544 Views)
Thanks a lot Smiley Very Happy. Ninskaya
(3,539 Views)
