11-26-2017 06:36 PM
Hi everyone, I hope someone can help me, the problem is that I am working with serial communication, so I am using VISA in labview, everything is ok with arduino uno, but the problem appear when I change it to an arduino Mega, with this the communication doesn't work so I used highlight execution in roder to see where was the problem and after around 4 seconds appear and error in the vi and it says "Error - 1073807360 ocurred at VISA Write" and reason "Unknown error miscellaneous error" I don't kwon why this happens because when I use the other arduino (UNO) the VI run perfectly, the problem is just with MEGA. I already worked with this arduino in the past, the problem started recently.
11-27-2017 09:50 AM
Hello kstude,
Have you tried changing the COM port? You could test the communication using another terminal software like Hyperterminal or DockLight to see if it a connection problem or programming problem.
11-27-2017 06:00 PM
Hi Fernando and thaks for answer, yes I tried many times using other COM, the arduino MEGA worked good in the past, I am thinking that is an arduino problem, because I use UNO and it works normally for that reason I think that is not a communication problem.
