04-16-2007 07:48 AM
04-16-2007 07:54 AM
hi Spring,
Have you looked at the info in in the KnowledgeBase? See here.
Is it describing something similar?
RayR
04-17-2007 08:31 AM
Hello Spring,
I'm going to guess that the first time you ran this VI that you did not receive this error - basically, this error means that something is already using your FP resource. Please look at the this documentation - it should fix the issue.
Good luck!
Janell R | Applications Engineer
04-18-2007 07:39 AM
Hi Janell,
Good catch. We're saying the same thing, but your description is much easier to follow. 🙂
It appears that somewhere in the code, the session was left open.
RayR
