error 1031/ error 1026
I made a change on a sub.vi (MFCCarrierScheath.vi) to (MFCCarrierSheathR1.vi). This change can be seen by the additional case structure surrounding the second to the right case structure in MFCCarrierSheathR1. This change has resulted in two errors:
1. Error 1031 occured at open VI reference in MCS-22.vi
2. Error 1026 occured at start asynchronous call in MCS-22.vi
Where MCS-22.vi is the main program.  Sorry for any inconveniance I may have caused my missing any necessary information, I am relatively new to labVIEW and extremely new to the forums.
(3,503 Views)
You made changes to the connector pane.  Therefore, you need to update the type specifier VI Reference to match your new VI.
(3,490 Views)
