error 1 pda emulator
Apparently the executable is generated correctly, in deploy option there is no error, but in option debug or run I get this error. So far I have not found information about it. If someone can help me to solve this please
thanks in advance
Message 1 of 9
(4,076 Views)
hi
one doubt: DAQmx Base works in the emulator?, I get the error 1 only when I try to run a vi acquisition , I found little information about it, anyone have any suggestions?
thanks,
Message 2 of 9
(4,043 Views)
this is true? NIDAQmx basis only works on the PDA device? but not on Windows Mobile 5?, I need to know whether it was true because I reinstalled all drivers and I have not succeeded in removing this error.
someone can give me a hint please? Smiley Sad
thanks for your time
Message 3 of 9
(4,023 Views)
help!Smiley Happy
Message 4 of 9
(3,982 Views)
Try loading the EXE you are getting the error with and the source code so we can take a look.  Have you tried to build one of the example VIs?  Do you get the same error with it?
Eric
Message 5 of 9
(3,974 Views)
Hi Eric
Thanks a lot, I have already tested with the example Vis, and only with data acquisition Vis is that I have problems with the Emulator, but I think if it's because the emulator does not run with DAQmx Base, but i would like to know certainty if this is true..
I attached my proyect (is a simple vi) with which I tried, but I tried with others and  i get the same error, i hope you can help me.
thanks for your time.
teresa
Message 6 of 9
(3,952 Views)
Sorry it took so long to reply.
But your thought is correct you can not use DAQmx Base VI's on the PDA emulator.  There is no way to install the necessary drivers on the emulator and there is no way to connect any daq hardware to the emulator.  The only way to debug DAQmx base code is on the device your are using.
Sorry I could not be more help.
Eric
Message 7 of 9
(3,936 Views)
Thanks Eric
It is all the help that I asked, thanks, thanks, I fully understand your explanation. Now I wait for the PDA to work. Thanks, thanks
having a great day ..
Message 8 of 9
(3,932 Views)
Smiley Happy
Message 9 of 9
(3,931 Views)
