error 1 occurred at thread
I occasionally get the following error when production is running.  Any help is where this is at?
23040iDF31BC28C0C09D05
(2,695 Views)
Error 1 generated by queue functions indicate an invalid queue reference. You have to debug your code to find out why your queue reference is invalid. You can use the NaN/Path/Refnum? function to test the queue reference and display a message if the queue is invalid or set a breakpoint when the output of that function indicates a True so you can then try to track what's causing it.
(2,682 Views)
