error 1 enqueue
Not knowing anything about your VI hierarchy... I've had problems like this where I put a control on the front panel but forgot to connect it to a terminal on the connector pane and as a result never wired the cluster into the VI that generated an error.  Any chance you've done something like that?
Message 11 of 18
(2,629 Views)
@crossrulz wrote:
@P Anand wrote:
Are you usnig the same code whatever you showed at the top? I see a stop function there what is that guy doing? I suspect that is closing evrything and you get invalid queue reference.
I agree that it shouldn't be there.  But I don't see that causing the problem (unless it's due to the memory leak we mentioned earlier).  The STOP is basically the same as hitting the Abort Execution button.  Not a nice way to end your application.  The VI should be able to end on its own.
I thought the whole vi is init thats why I suspected that. Anyway what will happen if the control thread vi completes before others (just trying to understand the issue)
Message 12 of 18
(2,627 Views)
First, regarding memory leaks and the use of stop.
It's hard for me to believe that aborting the VI makes a memory leak. The principle reason for this (at the moment) is that I want a button to be able to abort the VI always, regardless of if one of the threads is hanging, which is possible depending on the amount of processing. The control thread actually had a notifier which tells the other threads whether to shut down or not (and provides time for them to do so... about 1 second and it knows of the other threads have terminated since they send responses). Hopefully, the stop vi won't be necessary once I spend enough time seperating out the things that can hang (long scans, processing, etc) but I had it in there now so that I could push a button (while hiding the abort icon) and still get the abort functionality. Anyways, if this causes a 'memory leak', that's kind of ridiculous. The question would be, if I do use queues, and do need to abort occassionally, how would I fix the queues so they worked on the next run of the program. I doubt this is the issue, but if it is, how does one go about fixing it in the case the VI is aborted.
Second, regarding simply connecting the control.
I've disconnected and reconnected the wire 5 times. As I said, I removed the LVG and now it's just a straight wire into the threads! Tracing the wire through, it's unbroken and the only way that could happen and I have an invalid thread is if it's not physically connected to the source control but instead to a second source that isn't initialized properly. Even worse, it's worked in the past!
I can show the full path to where it fails:
Message 13 of 18
(2,622 Views)
Well, I don't know how many levels of hierarchy you have between the two probes in your image, but I would confirm that inside SL-UI.vi, the "program communicator interface" control is connected to a required terminal on the connector pane.  Then work one level up and check the same.  I think you'll find the point where the cluster references become invalid.
Despite the comments from others, I'm pretty sure this is purely a wiring error and has nothing to do with memory leaks, disposing of queues, etc.  Here's why: a queue refnum is an integer (with a wrapper around it).  "Not a Refnum" is a special value similar to NaN.  If the problem was that the queue was invalidated prior to calling the VI, you would still see those integer values as the queue refnums in the probe, they just would no longer be valid for queue operations.  Instead, you're seeing an entirely different value (a value that's a typical default), which suggests that there's a wiring problem and the values aren't carried through to the VI that needs them.
EDIT: For what it's worth, I just did a quick test to prove this, note that even after the queue ref is invalidated it still has a value:
Message 14 of 18
(2,613 Views)
Thanks everyone so far for helping.
While I have checked my wiring, what I will probably delete everything and rewire this section to test out your hypothesis. The two probes are directly 'adjacent' to eachother through the subvi call. So there is only one level difference between them.
However, this is even more interesting to me:
Okay, so what's happening here. All of thes SL* vi's are pretty symmetric: They bring in the pci and then with a normal tunnel pass the pci into a while loop in each of the vis. Now, as I watch right after the tunnel on the probes for each of these vis, I see them (well, all of the except the UI one) flicker to occassionally what the probe [6] says, though normally they are correct. Maybe this is just a bug in how the debugger works when polling the information inside the queue. I dunno, but it's pretty disturbing. Perhaps someone can tell me if this means I'm messing up somewhere. I thought it might be because I use these queues in different 'execution environments' so I tried to go in and change all the execution environments to the 'same as caller' and what not. That didn't seem to do anything. I'll continue debugging.
As I said, I've had this issue before and it just randomly comes and goes in my program.
Message 15 of 18
(2,608 Views)
Well, another similar explanation is that you accidentally put two copies of the "pci" control on the UI front panel, connected one of them to the connector pane and used the other in your code... I've been known to do that, too.
Message 16 of 18
(2,605 Views)
So, it was bound to be embarassing. But in SL - UI I was invoking on the application the function of setting all the front panel objects to their default values (as a lazy, temporary short cut to loading defaults into those values upon subsequent runs of the application... i'm currently working on saving and loading parameters for the UI). This bug would be more obvious if the icons for the queues changed visibly when they were empty or had a refnum associated ~.~.~.~.~
I still can't explain the other behavior I described (or the other issues I've had with the queues), but at least this is solved. Thanks for the help guys.
Message 17 of 18
(2,602 Views)
It occurs to me... if you're seeing this behavior, that means you're reading the "pci" control in a loop, which is inefficient.  You're running SL-UI as a subVI, so the value of the pci control does not change on each loop iteration (unless you do something like what you did, or you're displaying it to the user and allowing them to make changes which is unlikely for a cluster of queue refs).  Move that "pci" control terminal to the top-level of the VI (outside any loops, structures, etc).  This is both more efficient (see the classic "Clear as Mud" thread) and will solve the problem while still allowing you to use "Reinit to Default."
Message 18 of 18
(2,591 Views)
