erreur -63195
I have a VI with the compactRIO module, FPGA module, Real Time module ans Labview in 8.5 version.
I have recovered a existing VI from the last year, but it don't work.
I see the error code : -63195, I searched  different solving in your website, but the manipulation : tools, options, environnement "close automatiquelly the VISA session" don't work.
Do you have an other solution ?
Yours faithfully
Alexis
(3,714 Views)
Hello Alexis,
Thank you for posting on National Instruments Forum.
Thank to your explanation, I guess that you already read this KB:
http://digital.ni.com/public.nsf/allkb/CB82AC9CBC6C3F2386257241007A06EF?OpenDocument
Can you check in your LabVIEW.ini file (in the main LabVIEW directory under Program Files) for this line: "cleanupVisa=True" ? If you have this line, try changing it to ""cleanupVisa=False". If it isn't there, try adding it and then recompile your FPGA code.
If you get the error again, can you send us a screenshot of it and tell us in which VI it occures?
Also try repairing the NI-RIO driver (and then recompile).
Have a nice day,
Kind Regards,
Flo
(3,646 Views)
Thank you for your help,
I cheked my your LabVIEW.ini file (in the main LabVIEW directory under Program Files) for this line: "cleanupVisa=True" ? and thie line didn't exist. So  added cleanupVisa=False" and I saved the change.
But If I recompile my FPGACode, I have an error, and for the VI -> the same problem.
I joined you a copy of the compilation failure texte, a screenshot of my -63195 problem in my VI, and finally a copy of my project. I'm using the "HostCode 4" Vi.
The NI RIO drivers are succefully installed, normaly.
If you want, my collegue posted this same topic : http://forums.ni.com/ni/board/message?board.id=4170&message.id=27360#M27360
Thank you.
Kind Regards
Alexis
(3,638 Views)
Sorry,
I clicked on a false button. My problem is not solved.
I'm sorry for this false click, I need help !!
Thank You
(3,632 Views)
Please unmark by clicking on "Options" located at the top right corner of your post and select "unmark"
(3,627 Views)
Thank for your Help
I have just unmarked my post !
I'm still searching a solution.
Alexis
(3,622 Views)
