enum string to string
What is the best way to write a selection ring with a text label and command
Remote Input 1(label), RemoteInp_Value(command)
I was thinking of using enum but not sure how since I want to use two strings.
Soren
(1,723 Views)
Soren
For Enum, Writing the Strings is writable only during edit mode. if you no need to update the strings during runtime and its just for selection you can use enum.
(1,710 Views)
Accepted by topic author Soren74
You can use the "StringsAndValues" Property Node to change the text in a Text Ring programmatically.
=== Engineer Ambiguously ===
(1,676 Views)
