enter text flag
is there an elegant way to clear the "enter text" flag (tick in the top left of the toolbar) automatically...it prevents activex objects from running correctly unlil it is cleared
i can clear it by opening a popup window and then closing it but it is a hack
any suggestions would be appreciated
thanks
(3,009 Views)
I don't think the mere presence of that button is your problem, it just indicates that whatever you just typed has not been propagated to the code.
Try playing with the properties of the text input control (right-click on it). Play with the items "limit to single line" and "update while typing".
See if this helps. Else attach an example of your problem.
(3,004 Views)
altenbach
thanks for the reply
the field is not a text field but a shockwave activex object...it needs to be enabled and inputs are for the activex object and should be ignored by labview...disabling the object kills all input
i have attached a small vi to illustrate this
point the vi to the enclosed flash movie file (test.swf) and click to green button to move through pages...after the first click the "enter text" flag is set and the button looses functionality...clicking outside of the activex object will remove the flag and the button works as designed...for one more click at least
you will need the flash player on your system to run this
http://www.macromedia.com
(2,999 Views)
One way that you cna do this is to use an event structure. You can create an event for mouse down for the VI. You would get the coordinates for the mouse down event and if it's within the flash object, discard the event. In the attached example, I also used an event to stop the VI.
(2,984 Views)
pure genius
thanks
(2,965 Views)
