end of month
Hi all,
May I know how to get the value of End of Month (EOM)?? Like for example, if I select January it will display 31, for February it will display 28 (depends on leap year) and so on... THANKS!!!
Message 1 of 9
(5,827 Views)
Hi
This is just a combination of case-structure and a little math.
For the months January, March, May, Juli, August, October and December, the last day is the 31st.
For the months April, June, September and November, the last day is the 30th.
For February, you have to follow this rules:
1. Each year, dividable by 4 without rest is a leap year (e.g. 2004)
2. Each year, dividable by 100 is not a leap year (e.g 1900)
3. Each year, dividable by 400 is a leap year (e.g. 2000)
Thomas
Message Edited by becktho on 02-20-2006 08:05 AM
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 9
(5,819 Views)
Hello 222,
starting from LV7.0 you can use LabViews capabilities to calc dates using the timestamp control and "date/time to seconds"/"seconds to date/time" functions. LabView will check for leap years on its own...
Message Edited by GerdW on 02-20-2006 09:48 AM
Message 3 of 9
(5,810 Views)
Hello 222,
ok there was a glitch... Labview is not as smart as i thought it would be 🙂
Message Edited by GerdW on 02-20-2006 09:55 AM
Message 4 of 9
(5,803 Views)
Thanks guys.. Appreciate that... Smiley Happy
Message 5 of 9
(5,796 Views)
I have an activex control on my computer from Sheridan Calendar Widgets. It has a property node for days in month based on the current selection.
Message 6 of 9
(5,764 Views)
I currently had a similar problem. I solved it with simple comparison of month part of timestamp cluster:
Message 7 of 9
(4,391 Views)
Hi Jez,
so you need upto 30 iterations of this loop with upto 60 conversions from timestamp to datetime cluster for something easily done without any iterations as shown 13½ years ago?
And you provide your "solution" just as image of some code without handing out a snippet or VI? (Well, I didn't attach a VI at that time, too. But we didn't have snippets back then.)
Message 8 of 9
(4,354 Views)
Hello
Not the right solution. That doesn't take into account the time zone.
The code has to be modified to be fully working.
Cheers
Message 9 of 9
(1,300 Views)
