encoder measurement
I found this paper that shows how to take the encoder measurment,,, now there is VI front panel shown at the bottom of this paper.... Now Iam using an NI Elvis board to take measurement and I need to know the code for this front panel..
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1riCAA&l=en-US
(2,524 Views)
What's your questions?
(2,518 Views)
Well my question is that once I attached the input pins of my encoder to counter, which is built in to my DAQ board, how will I create the block diagram and front panel in the labview to measure outof the counter in the DAQ device. This paper I attached shows the front panel which the edge count indicator but does not show the block diagram.
SK
(2,500 Views)
SK0480,
Here is a link that explains how to use the quadrature encoder with NI Elvis.  If you follow the link at the bottom of the article, you will also find an example that illustrates how to implement this in LabVIEW.
Good luck with your project!
Trey C.
(2,474 Views)
