enable/disable windows USB device
 I was wondering how I could disable/enable a device plugged into USB through LabVIEW.  I have Windows XP and the device managers shows the USB device working properly and it also has the option of enabling/disabling a device at the same time.  Is there a way that LabVIEW can do this type of function as well?
Thanks for the help,
Gjoraas
(5,552 Views)
I believe you cannot do this directly from LabVIEW. What I would do is to use a search engine to search if there is a Windows DLL that has access to this and then call that DLL from LabVIEW using the Call Library Function Node.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(5,544 Views)
It is a windows tool called devcon that can help you. http://support.microsoft.com/kb/311272
You can run it with the "System Exec VI" Owning Palette: Libraries & Executables VIs and Functions
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(5,541 Views)
