Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
empty visa resource drop down menu box
After my system is restarted the visa resource drop down menu box is always empty even if I hit refresh unless I start up MAX then close it then the box gets populated again.  This is very inconvenient.  I'm using MAX 4.6.2 with LV 8.6.1 with all the services running.  Is there a way to resolve this issue without manually starting up MAX and then close it after each system reboot?
(2,532 Views)
Hi lavalava,
I tried recreating this issue on my machine and the visa resource box populated as would be expected. The version of MAX that you are using is a few back, I would recommend updating the VISA driver, which will bring the newer version of MAX with it, and then see if you are still experiencing this issue. I have include a link to the driver below.
http://joule.ni.com/nidu/cds/view/p/id/2251/lang/en
Peter W.
(2,504 Views)
