embedded web publishing error
Hi there,
I have some problem... I am trying to allow users to remotely control my labview program over the web (on a browser). I have all of the server information entered, and it's correct.
But when I want to browse the file at another pc that have installed Labview through the internet, the front panel  of the program could not be display.
I have read in the ni website that it's maybe because of the firewall. But I have asked my IT department that it is nothing to do with  firewall.
why this is happen?
Is there any other option to do remote control other than using web publishing tool..please help me...I need the solution as soon as possible.
Message 1 of 10
(6,351 Views)
hi   gdah
                     answer the following
1.the system which you want to see from the remote which is interanet connected.
2. in the tools----> options------> there so many things you want to enable ,,ex: vi server configuration ... you want to add the i.p address of the p.c from which u want to see ..
3. instaled labview run time engine in the pc uyou want to see...
try this i hope this may help u..........
Indrajit
| indrajitbarve@gmail.com | indar_indar2005@yahoo.co.in .
Message 2 of 10
(6,345 Views)
Hi..
Firstly, I have enabled the web server. I have put the ip address of the pc that I want to see the program. I also have installed a Labview 8.2 in the pc that i want to see the program which is run time engine also have been installed. I have done all the configuration before make the embedded web server. but still got the error..
Message 3 of 10
(6,336 Views)
hi
   one more thing .
open vi properties and select execution.
enable the reenterant execution.
i hope it helps....
Indrajit
Message 4 of 10
(6,331 Views)
hi
i dont think this is the reason, but check if you are having the actual vi/.exe open when you open the html page on the other pc.
that will not give the 'plugin' error, but check that.
also, see if its possible to give the html link here, and somone can try opening it.
you cannot access the code if the actual vi is not running/open in the server pc.
just chekc that
Message 5 of 10
(6,323 Views)
HEY!!
open it in Internet Explorer.. NOT Mozilla
Message 6 of 10
(6,319 Views)
hi everyone..
problem solved...thanks a lot....
Message 7 of 10
(6,299 Views)
what did you do to solve it?
post your solution so that it might help someone else
Message 8 of 10
(6,280 Views)
i had this problem earlier today.
you just have to install or drage the plugins in to the mozilla/plugins folder
Krispiekream
Message 9 of 10
(6,108 Views)
kindly reply about embedded web publishing error you solved.
Message 10 of 10
(5,925 Views)
