embedded sequence
I have a two-frame stacked sequence structure inside of a while loop. I want the sequence structure to execute repeatedly, but when I run the code it executes once and then the while loop goes off without executing the sequence again (see attached image.)  Note this is on FPGA
(3,999 Views)
No it doesn't.  Either you are explaining your problem incorrectly, or everything I know about LabVIEW is a lie.
The while loop will run repeatedly forever, doing case 0 then case 1 then back to case 0 again and again.
The iteration terminal will increase quickly depending on your values, and the index will incrase past the size of the array, then indexing the array will return a 0 which is the default value for the array.
I'm guessing you want a mod (quotient and remainder) to repeat back through the indexes of the array.
(3,978 Views)
Hooovah already gave you the answer, still some questions remain.
  • What's in the other frame (it would be so much clearer to use a flat sequence ;))
  • How often does the array data change (I guess the size is fixed on FPGA, right?)
(3,972 Views)
Based purely on the image given, I think you really want a FOR loop with autoindexing on the array.  No Index Array needed then.  If you want that process to repeat, you put it all inside of a While loop.
If you insist on keeping your current setup, then keep your index in a shift register and increment it.  Since you are in FPGA, I would advise against using the Quotient & Remainder function.  It uses a lot of gates and I think it cannot be done in a single cycle (would need to verify this).  Instead, do a check for Index equaling the array size and use a Switch to set the index to 0 if it is greater or equal to the array size.
(3,949 Views)
