embedded module ARM microcontroller
[1:45:29 AM] Status: Error
Build target 'LabVIEW'
compiling RTX_Config.c...
C:\Keil\ARM\RV31\INC\RTX_lib.c(183): error: #29: expected an expression
compiling File_Config.c...
compiling Retarget.c...
compiling TargetInit.c...
compiling ARM_irq.c...
compiling ARM_RTClock.c...
compiling ARM_Serial.c...
compiling EKLM3S8962_Display.c...
compiling LM3S_EMAC.c...
compiling ARM_I2C.c...
compiling ARM_SPI.c...
compiling LM3S_Pins.c...
compiling SPI_LM3S8962.c...
compiling ARM_Periph_Power.c...
compiling profile_timer.c...
compiling LVCGenIntInit.c...
compiling Blinky.c...
compiling lvEmbeddedMain.c...
compiling Headless.c...
compiling PosixFiles.c...
compiling CCGSemaphore_rtx.c...
compiling CCGStrSupport_rtx.c...
compiling CCGTimeSupport_rtx.c...
compiling LVCritSect_rtx.c...
compiling LVEvent_rtx.c...
compiling LVNBOps_rtx.c...
compiling LVThreads_rtx.c...
compiling OEM_LVISR_rtx.c...
compiling PlatformSerial_rtx.c...
compiling ARMCLib_rtx.c...
compiling LVInit_rtx.c...
compiling Error_rtx.c...
compiling SWI_rtx.c...
compiling ProfileSupport_rtx.c...
compiling CCGArrSupport.c...
compiling CCGArrSupport2.c...
compiling CCGArrSupport3.c...
compiling CCGClusterSupport.c...
compiling CCGCmplxSupport.c...
compiling CCGDVRSupport.c...
compiling CCGEnumSupport.c...
compiling CCGErrorSupport.c...
compiling CCGFltSupport.c...
compiling CCGFXPSupport.c...
compiling CCGIntSupport.c...
compiling CCGNotifier.c...
compiling CCGQueue.c...
compiling CCGRendezvous.c...
compiling CCGSemaphore.c...
compiling CCGStrSupport.c...
compiling CCGTimeSupport.c...
compiling CCGTokString.c...
compiling CCGUDClassSupport.c...
compiling CCGVariant.c...
compiling CCGXMLSupport.c...
compiling ExecStack.c...
compiling LVBlockDiagram.c...
compiling LVCGenRTInit.c...
compiling LVCGenScratchPad.c...
compiling LVContext.c...
compiling LVEvents.c...
compiling LVHeap.c...
compiling LVISR.c...
compiling LVTLExtSource.c...
compiling LVTdp.c...
compiling MemCheck.c...
compiling NumText.c...
compiling ObjList.c...
compiling ViLib.c...
compiling nbemptybin.c...
compiling nbfifo.c...
compiling nbfifo_inst.c...
compiling nbitemtable.c...
compiling occur.c...
compiling reentrant.c...
compiling rtmath.c...
compiling uScheduler.c...
compiling BgDebugTask.c...
compiling CCGAppRefSupport.c...
compiling CCGBtMgr.c...
compiling CCGBtSupport.c...
compiling CCGByteStreamFileSupport.c...
compiling CCGDatalogSupport.c...
compiling CCGFileSupport.c...
compiling CCGFileSupport2.c...
compiling CCGIrDASupport.c...
compiling CCGMachineAlias.c...
compiling CCGNetConnRefNum.c...
compiling CCGSerial.c...
compiling CCGUUID.c...
compiling CCGVIRefSupport.c...
compiling Debug.c...
compiling DebugComm.c...
compiling ExchangeMgr.c...
compiling FileRefNum.c...
compiling LVPhoneSupport.c...
compiling LVSMSSupport.c...
compiling OCDICheckPoint.c...
compiling SerialMessaging.c...
compiling VisaIntfc.c...
compiling crc.c...
compiling CCGChartGraphSupp.c...
compiling LVArrayControl.c...
compiling LVBoolean.c...
compiling LVChart.c...
compiling LVClusterControl.c...
compiling LVEnumCtl.c...
compiling LVFrontPanel.c...
compiling LVGraph.c...
compiling LVListbox.c...
compiling LVNumeric.c...
compiling LVRing.c...
compiling LVString.c...
compiling LVTab.c...
compiling LVTable.c...
compiling LVTimestamp.c...
compiling LVTree.c...
compiling Pict.c...
compiling arrresize.c...
compiling ARM_I2CWrapper.c...
compiling ARM_SPIWrapper.c...
compiling RLARM_Net_Config.c...
compiling RLARM_TCPMessaging.c...
compiling RLARM_TCPWrapper.c...
compiling RLARM_CCGTcpUdpSupport.c...
compiling RLARM_CCGNetConnSupport.c...
compiling RLARM_LVNetworkVarSupport.c...
compiling RLARM_CAN_Wrapper.c...
compiling SWare_adc.c...
compiling SWare_can.c...
compiling SWare_comp.c...
compiling SWare_cpu.c...
compiling SWare_epi.c...
compiling SWare_ethernet.c...
compiling SWare_flash.c...
compiling SWare_gpio.c...
compiling SWare_hibernate.c...
compiling SWare_i2c.c...
compiling SWare_i2s.c...
compiling SWare_interrupt.c...
compiling SWare_mpu.c...
compiling SWare_pwm.c...
compiling SWare_qei.c...
compiling SWare_ssi.c...
compiling SWare_sysctl.c...
compiling SWare_systick.c...
compiling SWare_timer.c...
compiling SWare_uart.c...
compiling SWare_udma.c...
compiling SWare_usb.c...
compiling SWare_watchdog.c...
Target not created
Status: Build failed.
I currently working on my FYP(Final Year Project) with using LabView to connect with ARM Microcontroller board EKK-LM3S8962, whenever i try to compile the sample privoded in the [Find Example], this series of code come out. I already uninstall and reinstall back my Keil and ARM Module for few time but didnt manage to solve this problem. Any other suggestion for me ?
(3,420 Views)
Huan_Run hello, keep in mind that the examples designed for the ARM microcontroller LM3S8962 diselados are to be downloaded to the recorder ULINK2 Keil JTAG, programs can also download the USB connector mediente, but you must re-create the examples and compile with that discharge destination after loss programs that work
(3,293 Views)
