email verification
 I want to verify email-id and its corresponding password.
Can anyone help me regarding the same using either .net or smtp etc
Thanks in advance
(3,999 Views)
What code have you tried? There are SMTP functions available in LabVIEW - you might be able to use one of them as the basis for a VI which just tries to login to the server via TCP without sending an email.
(blog)
(3,969 Views)
Thanks for ur time..
I tried with simple open session , add recipients and send mail...I am new to this topic...if d email n password is not correct it throws an error.. How to implement your idea..
(3,926 Views)
Hi rakr,
if you have already a lists of the email ids and password then you can try to develop a simple code to find a match for those fields.
It's like finding a specific key in a 2d array and you need to check for each field (email id and password).
(3,894 Views)
